SpotlightConnecting rigging objects
Tool
Tool set
Insert Connection
Rigging/Braceworks
The Insert Connection tool either connects rigging objects with a drop or stacks them with a truss cross connection. When stacking rigging objects, you can choose to move the object to be stacked either up or down, and select which object to move to bring the rigging objects into parallel alignment, if needed. Rigging objects to be connected should have cross section data.
The Automatic truss cross insertion parameter in the Spotlight preferences creates a truss cross automatically when inserting crossing, touching trusses.
Mode
Description
Insert Drop
Creates a connection between two rigging objects by placing a dead hang bridle or a hoist at the clicked point
Place Rigging Object on Top
Stacks a rigging object above another one, moving a truss and all its associated supports and loads on top of the reference truss. A truss cross is created at the connection point.
Place Rigging Object Below
Stacks a rigging object under another one, moving a truss and all its associated supports and loads below the reference truss. A truss cross is created at the connection point.
Preferences
Opens the Connection Options dialog box to specify the drop type for Insert Drop mode, and to select the truss cross connection symbol for all of the insertion modes
Enable Vertical Offset
Toggles the offset insertion on and off
Offset
If Enable Vertical Offset is on, adds the specified distance between the top truss and bottom truss.
For rigging objects connected with drops, the truss to move adjusts to meet the specified offset distance. To change the offset value, see Changing the trim height of a system.
For rigging objects connected with truss crosses, the offset value is added to a default distance of 0” between trusses. The Offset can be edited from the Object Info palette of the selected truss cross object.
Automatic Numbering
When toggled on, enables automatic numbering as objects are placed
Automatic Numbering Preferences
Sets the automatic numbering preferences
Connecting rigging objects with drops
To connect structural elements with one or more drops:
Click the tool, and then click Insert Drop mode.
If an offset is needed, enter the Offset value and toggle Enable Vertical Offset on.
To automatically number truss crosses as they are placed, click Automatic Numbering, and then click Automatic Numbering Preferences; see Numbering objects at placement.
Click Preferences to open the Connection Options dialog box. Select whether to insert the drop as a dead hang bridle or a hoist; if inserted as a hoist, from the Resource Selector, select the hoist symbol for the drop. If desired, select the option to use a truss cross symbol for the connection, and select the symbol from the Resource Selector.
Click on the reference rigging object; this truss does not move.
Click on the rigging object to move either up or down (stacking the moved truss below or above).
Valid rigging objects are highlighted, and a preview of the drop location displays.
Click to place the drop at that location and connect the rigging objects.
If the trusses to be connected require adjustment to be stacked in a parallel alignment, the Move Parallel Systems for Drop dialog box opens. Select whether to move the top truss system (the one with the higher Z value) or the bottom truss system into correct alignment. The selected item is moved.
In some cases, when changing the high hook height of a hoist inserted with the Hoist tool, you can choose to ignore the potential association with the truss.
The selected hoist is inserted.
Connecting rigging objects with a truss cross
To connect rigging objects to each other with a truss cross:
Click the tool, and then, depending on whether you want to stack a truss above or below another one, click either Place Rigging Object on Top or Place Rigging Object Below mode.
To automatically number drops as they are placed, click Automatic Numbering, and then click Automatic Numbering Preferences; see Numbering objects at placement.
Click Preferences to open the Connection Options dialog box; select whether to use a symbol for the truss cross, and if so, from the Resource Selector, select a truss cross symbol. If you don't select a symbol, a rigid truss cross is inserted.
Click on the reference truss; this truss does not move.
Click on the truss to move (stacking the moved truss above or below the reference truss).
The truss is stacked with the reference truss, and any connected hoists, attached loads, and supports move with the truss. If hoists are connected between the trusses, they are removed; hoists connected to other truss sections may be lengthened or shortened.
A truss cross is created at the connection point. A truss cross indicates how to calculate and model the connection between stacked trusses. Depending on the selected symbol, its appearance indicates the type of connection (whether it is connected, flexible, or rigid; can transmit all forces, or only tension or only compression forces, or no forces). A label indicates the truss cross's name, type of connection, and the current force.
The truss cross parameters can be edited later from the Object Info palette.
Parameter
Description
Properties
Name
Enter a truss cross name
Maximum Force
Specifies the maximum allowable force for the truss cross
Force
Displays the calculated force (Braceworks required)
Connection Type
Indicates whether the truss cross is rigid, pliable, or not connected; a truss cross that does not transmit any forces is considered not connected
Transmitted Forces
Indicates whether the truss cross can transmit all forces, or only tension or compression. Rigid truss crosses always transmit all forces. If the truss cross is not connected, this parameter is not available.
Display
Show Symbol
Display the selected symbol instead of default geometry
Select Symbol
Displays the symbol used to represent the truss cross, and opens the Resource Selector. The generic truss cross representation can be switched to use a symbol instead. From the Resource Selector, double-click a different resource to apply it.
Offset
Sets the vertical offset between the top truss and bottom truss; the value can be 0-300 mm (0-11.8 inches). If you change this value from the Object Info palette, you are prompted to select whether to move the top or bottom truss system to apply the new offset.
Classes
Opens the Classes dialog box to control appearance and visibility of the truss cross parts; do one of the following:
Click Use Standard Classes to set the class names for the truss cross parts to the standard.
Select a class from the list of classes present in the drawing, or create a new class. Select <Object Class> to place the part attributes in the same class as the truss cross object.
Select similar objects
Objects of same name
Selects truss cross objects with the same Name parameter
Objects of same connection type
Selects truss cross objects with the same Connection Type parameter
Objects of same transmittable forces
Selects truss cross objects with the same Transmitted Forces parameter
Concept: Rigging objects
Placing hoists
Numbering Spotlight objects
Inserting connections automatically
Specifying cross section data
Spotlight preferences: Loads and Rigging pane
